What is a fail-safe PLC?
Designed to move into a safe state in the case of a failure such power outage, system error, or hardware malfunction, a fail-safe PLC (Programmable Logic Controller) The fundamental idea underlying fail-safe design is that no extra energy or action should be needed to halt the operation and guarantee safety a major principle in industrial automation safety.
Usually, important devices like emergency stop pushbuttons are normally closed (NC) in a fail-safe system. This means they pass a signal during normal operation; any power loss or wire breakage causes an open circuit that automatically removes power from actuators and stops processes. This natural quality guarantees that a failure causes a safe stop situation without depending on outside assistance.
Siemens SIMATIC S7 F-series, for example, modern fail-safe PLCs include built-in safety mechanisms including redundant CPUs, self-diagnostics, and monitoring tools. Plug-in I/O, connectivity, and function modules allow these systems to be easily scaled, hence enabling their use in a variety of applications.
Fail-safe PLCs follow international safety standards such EN 954-1, ISO 13849, and IEC 61508, which categorize systems into categories (Cat. B to 4) depending on their risk assessment and dependability. Category 4 systems, for instance, offer the greatest degree of risk reduction and are usually employed in important uses including nuclear plants or chemical factories.
Unlike general-purpose PLCs, safety PLCs stress redundancy and internal diagnostics to identify flaws before they develop into dangers. Companies such as Pilz, Siemens, and Schmersal offer certified safety PLCs able to satisfy these exacting criteria.
A fail-safe PLC controls industrial operations but also guarantees that, in any failure situation, the system switches to the safest possible condition.
Fail‑Safe PLC (F‑PLC) Translation
A Fail‑Safe PLC (abbreviated as F‑PLC) is a programmable logic controller designed in accordance with the core principle of Fail‑Safe, featuring hardware redundancy, safety‑certified software, and full‑link fault diagnosis. When faults occur in its internal hardware, external sensors, actuators, or communication circuits, it forces the system into predefined safe states (emergency stop, power cut‑off, interlock lockout) to prevent personal injury, equipment damage, and environmental accidents, which fundamentally differentiates it from standard PLCs.
I. Core Design Philosophy (Fundamental Differences from Standard PLCs)
Standard PLC: Primarily designed to ensure normal equipment operation and process control execution. In the event of a fault, it may lose control, trigger unintended actions, or continue operating abnormally.
Fail‑Safe PLC: Focuses entirely on safety during failures. Regardless of anomalies in the CPU, I/O modules, circuits, or programs, it triggers an immediate safety shutdown to prohibit any hazardous operations.
II. Core Hardware Architecture (Represented by Siemens F‑PLCs)
Dual‑Channel Redundant CPU: Two CPUs perform independent calculations with real‑time cross‑checking. A discrepancy in calculation results triggers an immediate safety shutdown, eliminating single‑point failures.
Fail‑Safe I/O Modules (F‑I/O):
◦ Adopt dual‑channel signal acquisition and output to detect circuit short circuits, open circuits, and sensor failures;
◦ Lock outputs and maintain a safe state upon faults to prevent unintended actuation.
Dedicated Safety Communication: Utilizes the PROFIsafe protocol to ensure interference‑free and lossless transmission of safety signals.
Full‑Link Self‑Diagnosis: Continuously monitors the CPU, memory, bus, I/O modules, and field circuits for faults and generates precise alarms.
III. Software and Certification Standards
Safety Programs: Employ certified and encrypted safety function blocks (for emergency stop, safety gate interlocks, safety light curtains, etc.). Custom modification of safety logic is prohibited to avoid program vulnerabilities.
International Safety Certifications: Compliant with IEC 61508 (SIL1‑SIL3) and EN ISO 13849‑1 (PL e/Cat.4). Siemens S7‑1200F/1500F/300F series achieve the highest industrial safety level of SIL3.
Integrated Operation: Supports simultaneous execution of standard control programs and safety programs, eliminating the need for separate safety relays and simplifying control cabinet integration.
IV. Typical Application Scenarios (High‑Frequency Scenarios for Industrial Control and Project Integration)
Mechanical Manufacturing: Emergency stop, safety gate interlocks, and safety light curtain protection for robots, CNC machine tools, and packaging lines;
Process Industry: Emergency Shutdown (ESD), Burner Management Systems (BMS), and high‑pressure protection for chemical, energy, and pharmaceutical facilities;
Rail Transit: Train signal interlocks and anti‑collision protection;
High‑Risk Equipment: Safety control for hoisting machinery, high‑voltage equipment, and explosion‑proof production lines.
V. Common Siemens Fail‑Safe PLC Models (Selection for Control Cabinets and Project Integration)
S7‑1200F: Compact F‑PLC for standalone equipment and small‑scale production lines;
S7‑1500F: Mid‑to‑high‑end mainstream model suitable for large‑scale production lines and complex processes, with SIL3 certification;
S7‑300F/400FH: High‑end redundant models for chemical Safety Instrumented Systems (SIS) and large‑scale interlock projects;
Key Feature: Combines F‑series CPUs with F‑safe I/O modules. Standard I/O modules can be used for routine control, while safety loops are exclusively executed by safety‑certified modules.
VI. Concise Summary (Quick Reference for Industrial Control Professionals)
Standard PLCs ensure equipment operates normally, while fail‑safe PLCs guarantee absolute safety for personnel, equipment, and the environment when failures occur. They are mandatory core components for safety loops in high‑risk industrial scenarios and control cabinets.
