What impact does the rotor slot have on torque and power of an induction motor?
The design of the slot significantly affects the torque and power properties of an [url= Three-Phase Induction Motor: Working Principle, Components and Formulas][color=#1E00A3] induction motor [/color][/url].
Some of the slot parameters include the number and disposition of slots, geometry, and skewing, which influence the motor performance significantly.
[color=#f80404]Effect of Rotor Slot Number[/color]
[color=#ff7700]Torque and Power Output[/color]
The amount of consequence in the stator depends on the number of slots in the rotor to create the electromagnetic torque and power for the motor. According to the studies, raising the number of rotor slot can improve the electromagnetic torque.
Ex: It was determined that increasing the number of slots in the rotor from 28 to 36 helped to improve the electromagnetic torque by six percent. On the other end, lower value of slots can result in low output power and efficiency which was observed in motors with 24 slots on rotor side.
[color=#ff7700]Harmonic Reduction[/color]
The physical entity of the rotor with more slots can be helpful in reducing harmonics that may be present in the air gap flux hence the output torque can be smoother.
This is important because harmonics can cause cogging torque and this may limit the motor from starting properly.
Another important feature of constructing rotors is the skewing of slots, which consist in tilting the slots to a certain angle, and also helps to reduce these harmonics and level the torque.
[color=#f80404]Impact of Rotor slot Shape[/color]
[color=#ff7700]Slot Depth and Width[/color]
The depth and width of slots in the rotor influence the resistance and reactance of the rotor.
This implies that any change in the above mentioned parameters results in changes in the
  • Losses,
  • Output power and
  • Speed characteristics.
A parametric analysis illustrated that adaptations of the dimensions of rotors’ slots may impose a positive impact on rated torque.
[color=#ff7700]Skewing Advantage[/color]
Such an axial displacement, or skewing, of the rotor slots has several objectives:
It increases the mean length of the rotor bars and thus increases the starting torque and decreases the starting current.
It assists in attaining a more uniform air gap flux density distribution, thus reducing the degree of torque variation and noise level.
[color=#f80404]Conclusion[/color]
Therefore, the design of rotor slots is a major factor in the induction motors which determines the rate of torque and the power generated. It may be understood from this combination of research that geometry and skewing of rotor slots have significant bearing on the motor performance in terms of its efficiency, harmonics, and starting torque. These factors are critical when it comes to the use of induction motors in different applications.
