What happens when an AC line touches a DC line?
When an AC line touches a DC line, the result depends on the
Voltage level,
Grounding system,
Circuit design and
Protection devices.
In most cases, it is a dangerous fault condition and can damage equipment.
Possible Effects:
1. Equipment Damage
DC equipment may get damaged because it is designed for constant polarity voltage, not alternating voltage.
AC devices connected to the circuit can malfunction if exposed to DC.
2. Short Circuit / Fault Current
If both systems are energized and interconnected, a high fault current may flow.
This can trip protection devices like MCB, MCCB, fuse, or relay.
3. Overheating
Wires, transformers, rectifiers, batteries, and electronic circuits may overheat due to abnormal current flow.
4. Protection Operation
Circuit breakers, relays, fuses, or protective devices may operate to isolate the fault.
5. Battery/Rectifier Damage
In DC systems (110V/220V battery banks, chargers, UPS), accidental AC contact may damage:
Rectifiers
Batteries
Control circuits
Protection relays
6. Shock and Safety Hazard
Creates a severe electric shock risk and may lead to arc flash or fire.
