A negative ground system is an electrical design that connects the negative terminal of a power source, including a battery, to the ground. This system is widely utilized in automobiles and other industrial applications.
Features of Negative Ground Systems
In a negative ground system, the vehicle or equipment’s chassis serves as the ground reference point. The negative terminal is connected to this ground, and the positive terminal is deemed “hot” or live.
Electrons move from the negative terminal to the positive terminal. This flow direction is important for understanding circuit function, even though conventional current flow is commonly represented as going from positive to negative.
In negative ground systems, red wires are employed for positive connections and black wires for negative connections. This color coding helps to avoid confusion during installation & maintenance.
Advantages of Negative Ground Systems
Negative ground systems can assist decrease corrosion caused by electrolysis in the presence of moisture. This was a fundamental reason for their acceptance in automotive applications over positive ground systems.
Many modern automobiles and equipment use negative ground systems, making it easier to combine components and maintain consistency across multiple manufacturers and models.
Applications of Negative Ground Systems
Most modern automobiles have a negative ground system for their electrical circuits.
While telecom systems frequently use positive ground setups for specific reasons, many other DC-powered applications still use negative grounding principles.
