Differential Temperature Measurement
Measure and output the difference between two process temperatures
Average Temperature measurement
Measure and output the average of process temperatures
Redundant temperature measurement
Device switches to backup sensor upon failure of primary server
Dual Range Switching / Split range measurement
Make use of the best possible accuracies of two different sensor within the single measurement range to improve the accuracy throughout the range
Sensor Drift Alert
Alert the user about drift in the sensor by monitoring the difference between sensor 1 and sensor 2 against a preset delta value.
