A feedback control system is an essential system used in many engineering applications to sustain desired outputs by constantly modifying inputs based on feedback.
The essential elements of such a system can be described as follows:
Key Components of a Feedback Control System
Input (Setpoint)
This is the targeted value for the controlled variable. It represents the system’s desired outcome, such as a specified temperature or speed.
Process (Plant)
The process (plant) is the system being controlled, which could range from a heating unit to a production line. It produces the production that must be regulated.
Output (Process Variable)
The actual value of the variable under control, such as current temperature or speed, is measured and compared to the setpoint.
Sensing Elements (Sensors/Transducers)
These devices measure the output variable and transform it into a signal that can be manipulated. They offer real-time information about the current condition of the output variable.
Controller
The controller compare the measured output to setpoint, determines the error (the difference between desired & actual values), and determines the corrective action required to reduce this error.
Actuator
This component carries out the remedial action specified by the controller. It changes the process based on the controller’s output, affecting the process variable to reach the setpoint.
Feedback Loop
This mechanism sends information about the output back to the controller, allowing for continual system monitoring and adjustment to ensure stability and accuracy.
Functionality Overview
The feedback control system works by continuously monitoring the output variable with sensors, comparing it to the setpoint utilizing a controller, & making modifications with actuators to eliminate any disparities. This closed-loop technique stabilizes operations and improves performance by responding dynamically to system changes or disturbances.
Example
An air conditioning unit is a typical example of a feedback control system.
Input: The desired room temperature is set via a remote.
Output: A sensor measures the actual room temperature.
Process: The process involves the air conditioning system itself.
Sensing Element: Temperature sensor that measures the current temperature.
Controller: Compares the actual temperature to the setpoint and determines necessary modifications.
Actuator: A compressor that modulates cooling in response to controller signals.
This regular interaction ensures that any variation from the appropriate temperature is quickly rectified, keeping comfort within a specific range.
