What are the different Coupling technics to reduce Noise?
[color=#1C4587][size=3]Modern instrumentation systems based on digital signals are very sensitive to any noise and signal distortion due to noise, for high frequency (hf) switching. [/size][/color]
[color=#1C4587][size=3]Therefore it is necessary to use modern wiring techniques and better quality cables to achieve a better solution. The following are noise-coupling techniques:[/size][/color]
  • [color=#1C4587][size=4]Conductive coupling(common impedance)[/size][/color]
  • [color=#1C4587][size=4]Capacitive coupling(electric field)[/size][/color]
  • [color=#1C4587][size=4]Inductive coupling(magnetic field)[/size][/color]
  • [color=#1C4587][size=4]Radiative coupling(electromagnetic)[/size][/color]
[color=#ff0000][size=5]Conductive coupling:[/size][/color]
[color=#1C4587][size=3]When a common junction/wiring is shared by two circuits, such as a common return path, then noise or interference occurs. This could be intentional for grounding or could be from undesired leakage between the two circuits.[/size][/color]
[color=#1C4587][size=3]Current in one circuit may appear as noise in the other circuit and depends on the prevalent impedance value. Thus any ground potential at various locations in the plant. [/size][/color]
[color=#1C4587][size=3]These can happen even if the receiving tool has elevated prevalent mode rejection (CMR) and the shield is not terminated or terminated properly at two points giving rise to a ground loop.[/size][/color]
[color=#ff0000][size=5]Capacitive coupling:[/size][/color]
[color=#1C4587][size=3]In all portions, such as between the insulated conductors, there is capacitance. [/size][/color][color=#1C4587][size=3]Any shift in voltage regardless of place will attempt to push a current through the different possible coupling capacities in the circuits, as a circuit shown below:[/size][/color]
[color=#1C4587][size=3]Due to capacitance coupling, the duration of two parallel wirings will boost the noise (particularly during hf switching). It is more prone to high-impedance circuits.[/size][/color]
[color=#ff0000][size=5]Inductive coupling:[/size][/color]
[color=#1C4587][size=3] There might be many closed loops with mutual inductance, which is proportional to a closed-loop area, as shown in:[/size][/color]
[color=#1C4587][size=3]There is a transformer impact that applies similarly to a DC circuit whenever its current is disrupted or periodically shifts (E 1⁄4 M dI / dT). This coupling increases the function of the coupling conductors ’ length and decreases function to their range.[/size][/color]
[color=#ff0000][size=5]Radiative coupling:[/size][/color]
[color=#1C4587][size=3]The circuit / loop path within the interfering source’s electromagnetic radiation profile. The voltage from these field pairs is normally prevalent mode voltage.[/size][/color]
[color=#1C4587][size=3]This coupling is proportional to the loop area and frequency. Even though these frequencies may be much higher than the control circuits, they still cause harmonic interferences.[/size][/color]
