Variable Frequency Drives (VFD) manage the speed & torque of electric motors. They use a wide range of control methods to accomplish this, including:
Volts per Hertz (V/f) Control
Vector Control
Sensorless vector control
Direct Torque Control (DTC)
Slip Compensation Control
Sensorless Speed Control
Closed-Loop Control
- This is the most popular way. It maintains a stable V/f ratio, allowing for proportional changes in voltage and frequency.
- Ideal for basic applications like as fans or pumps.
Vector Control
- Vector Control, is additionally referred to as Field-Oriented Control (FOC) (or) Vector Control.
- Provides exact control over motor speed & torque.
- Divides motor current into 2 components: torque-producing & magnetizing current.
- Enables autonomous control of these components, resulting in improved performance.
- Sensorless vector control is similar to vector control however eliminates the need for speed and location sensors.
- Uses algorithms to estimate rotor position, making it less expensive applicable to a wide range of applications.
- Direct Torque Control (DTC) provides superior dynamic performance.
- Controls torque & flux directly, without the need for a coordinate transformation.
- Provides fast reaction and fine control over motor parameters.
- Slip Compensation Control is utilized in applications where the motor speed must closely match the synchronous speed.
- Adjusts for slip in induction motors to keep the desired speed.
- Ideal for applications that require motor speed control without using speed sensors.
- Estimates and controls motor speed using algorithms and model information.
Closed-Loop Control
- Uses feedback sensors such as encoders or tachometers.
- Enables precise speed & position control.
- Ensures that the motor performs as expected, even under changing load conditions.
The VFD control mechanism used is determined by the unique application, performance requirements, & cost factors. Each method has advantages and disadvantages, so choosing the right one is important for gaining optimal motor control.
