Common NFPA 70E Violations:
1). Failure to do an Arc Flash Risk Assessment
2). Inadequate or non-rated apparel in Arc Flash Zones
3). Working with Energized Equipment without Justification
4). Lack of Training
5). Inadequate (or) incomplete Lockout/Tagout (LOTO) Procedures
6). Unlabeled (or) Incorrectly Labeled Electrical Panels
7). Improper Maintenance of Electrical Equipment
8). Improper Utilization of Test Equipment
9). Inadequate Documentation
10). Unauthorized Persons in Electrical Areas
Not performing a proper arc flash analysis.
Using old (or) generic arc flash labels.
There is a lack of documentation regarding hazard boundaries & incident energy levels.
Avoid employing voltage-rated gloves, face shields, (or) balaclavas.
Using common apparel that can melt (or) ignite.
Conducting maintenance (or) testing on active circuits without demonstrating that de-energization was not feasible.
There is no documented Energized Electrical Work Permit (EEWP).
Employees have not been instructed on electrical risks, shock boundaries, or the proper use of personal protective equipment.
Training records are not maintained (or) updated at the required three-year interval.
Failure to isolate energy sources prior to starting work.
Incomplete or absent written LOTO plans.
Utilization of non-compliant locks and tags.
Panels without arc flash markings or hazard warnings.
Voltage ratings and breaker schedules are incomplete.
Not maintaining breakers, switchgear, (or) transformers in accordance with manufacturer specifications.
Ignoring dust accumulation, corrosion, or loose connections, which enhance risk.
Utilizing uncalibrated (or) non-rated meters to verify voltage.
To check the lack of electricity, skip the “live-dead-live” test method.
No Electrical Safety Program (ESP) is in existence.
There are no occupational safety plans or work justifications that are energized.
There are no records of training, audits, (or) PPE issue.
Non-qualified workers are permitted in restricted or electrified locations.
There are no signs or barriers surrounding live equipment.
