What are calibration management softwares?
[color=#ff0000][size=5]What is the calibration management software?[/size][/color]
Calibration software is an application that manages the calibration process through computer control. Calibration software allow to Plan, make the decision, document result and analysis.
[color=#ff0000][size=5]Why a calibration software is needed?[/size][/color]
Using calibration software can earn ease of work and put a reminder on periodic calibration. These are the main advantages of using calibration software:
Efficiency:
Automating the process of calibration allows technicians to set up tests and then proceed to perform other tasks, making their time more efficient. Usually, calibrations are done much quicker, saving time and money. If the software is capable of simultaneously calibrating multiple units under test, automation will also increase the performance.
Consistency:
Software automation means that multiple operators in multiple locations and over time can perform the calibration exactly the same way. This improves the quality of your performance and reduces mistakes.
Documentation and reports:
Calibration software helps to create procedural documentation and allows calibration data to be stored and reports to be produced so that paper records or spreadsheets can be removed.
[color=#ff0000][size=5]How to choose calibration software?[/size][/color]
Easy to use:
The software should be understandable and easy to learn for the user. Interface should intuitive
Does it handle the required workload?
Check your calibration tools and your workload and ensure compatibility with the software you select. You should also try to look forward to knowing what your needs might be from now on one, five or even ten years. So you can choose a scalable solution that can evolve with you as your needs change.
Features:
Check the feature of the software to ensure the features provided are sufficient for your needs.
Standard requirements:
You may want or need to follow the traceability and documentation criteria of international quality and accreditation standards, including ISO / IEC 17025, ISO 9000, QS 9000, EN 45000, ANSI Z540, and MIL-STD 45662A, without writing your own systems, setting up your own databases, or checking and documenting your system.
Data management:
While you can select various specialized applications for electrical, temperature, pressure, flow, or dimensional calibration, can you manage all the data in one database?
Kinds of support provided:
Some developers of calibration software offer premium support programs to maximize productivity and minimize downtown.
The manufacture of giving the training is plus to consider the vendor.
