Greetings!
It’s my first topic in this forum, and I hope it will be interesting for you!
I believe a most of you familiar with 2ooN logic (SIS, FGS, BMS etc. applications). And if you are, then you should know how it works. Normally, the logic of 2ooN uses binary to number conversion and mathematical operation – addition. I think it’s not reasonable usage of CPU load. I believe, the 2ooN must use binary elements only!
Here is example of my simple binary logic of 2ooN.
I would be grateful to know your opinion.
Best regards, Kairat Abdukarimov, Process Automation Engineer.
