Accurate Voltage Drop Equation
It is common practice for voltage drop calculations to be performed by hand using simple equations.
The use of simple voltage drop equations results in larger cable sizes, every time.
Instead, an accurate voltage drop equation should be used that considers:
1). Cable resistance at conductor operating temperature.
2). Cable reactance.
3). Load power factor.
The accurate voltage drop equation for three-phase cable systems is given as:
