VFD Faults & Troubleshooting
1) OC / OCF – Over Current Fault
Causes:
  1. Mechanical overload / jam
  2. Short circuit / insulation failure
  3. Sudden load pickup
  4. Very low acceleration time
Checks:
  1. Measure motor current vs FLA
  2. Megger motor + cable (IR ≥ 1 MΩ/kV)
  3. Inspect coupling, bearings, gearbox
  4. Increase accel time
Protection ref: ANSI 50 / 51, VFD I²t model
Tip: Always enter correct motor rated current in parameters.
2) OV – Over Voltage Fault
Causes:
  1. Regenerative load (crane, lift, downhill conveyor)
  2. Fast deceleration
  3. High incoming voltage
Checks:
  1. Monitor DC bus (typically trips at ~1.35 x Vdc rated)
  2. Increase decel time
  3. Install braking resistor / chopper
Protection ref: ANSI 59
Tip: Regeneration energy must be dissipated, not blocked.
3) UV – Under Voltage Fault
Causes:
  1. Weak grid / transformer
  2. Loose MCC terminals
  3. Phase drop
Checks:
  1. Measure line voltage under load
  2. Tighten MCCB/contactor
  3. Check phase balance (<2–3%)
Protection ref: ANSI 27
Tip: UV = upstream electrical problem in 80% cases.
4) OL – Overload Fault
Causes:
  1. Continuous mechanical overload
  2. Wrong motor sizing
  3. Wrong cooling class
Checks:
  1. Verify kW matching (motor vs VFD)
  2. Inspect driven equipment
  3. Check thermal class (Class F/H)
Protection ref: ANSI 49
Tip: Mechanical problem first, electrical second.
5) OH / OT – Over Temperature Fault
Causes:
  1. Fan failure
  2. Dust & clogged heatsink
  3. Poor panel ventilation
Checks:
  1. Clean heatsinks
  2. Verify fan RPM
  3. Maintain panel temp < 40°C
Tip: Every 10°C rise = ~50% reduction in VFD life.
Professional troubleshooting sequence (always follow):
  1. Note exact fault code
  2. Measure supply voltage & phase balance
  3. Measure motor current
  4. Megger motor & cables
  5. Verify parameters
  6. Inspect mechanical load
  7. Check cooling system
