VFD Control for Three Phase Induction Motors
Variable Frequency Drives (VFDs) are widely used in industrial automation to control
  1. Motor speed,
  2. Improve efficiency and
  3. Reduce starting current.
Here are some key concepts behind VFD motor control:
Motor Speed Formula
N = (120 x f) / P
Where
N = Synchronous Speed (RPM)
f = Frequency (Hz)
P = Number of Poles
Example
For a 4-pole motor at 50 Hz
N = (120 × 50) / 4 = 1500 RPM
V/F Control Principle (Volts per Hertz)
VFD maintains constant magnetic flux by adjusting voltage proportional to frequency.
For a 415V and 50Hz motor:
V/F ratio = 415 / 50 = 8.3
If frequency reduces to 25 Hz
Voltage ≈ 25 × 8.3 ≈ 207 V
Three-Phase Motor Current Formula
I = P / (√3 × V × PF × η)
Where
I = Line Current
P = Power (W)
V = Line Voltage
PF = Power Factor
η = Efficiency
Example (7.5 kW motor)
I ≈ 12.9 A
Motor Speed vs Frequency (4-Pole Motor)
  1. 50 Hz → 1500 RPM
  2. 40 Hz → 1200 RPM
  3. 30 Hz → 900 RPM
  4. 25 Hz → 750 RPM
Understanding these relationships helps engineers properly configure VFDs, optimize motor performance and improve energy efficiency in industrial systems.
