Ohm’s Law
I =E/R
or E = IR where I = current (amperes) E = electromotive force (volts) R = resistance (ohms)
Conductor Resistivity R = ρ*L/a
where ρ = specific resistance (or resistivity) (ohm metres, Ω·m) L = length (metres) a = area of cross-section (square metres) Temperature correction Rt = Ro (1 + αt) where Ro = resistance at 0ºC (Ω) Rt = resistance at tºC (Ω) α = temperature coefficient which has an average value for copper of 0.004 28 (Ω/ΩºC) R2 = R1 * (1 +αt1 ) /(1+ αt2 )
where R1 = resistance at t1 (Ω) R2 = resistance at t2 (Ω)
α Values Ω/ΩºC copper 0.00428 platinum 0.00385 nickel 0.00672 tungsten 0.0045 aluminum 0.0040
Alternating Current
R.M.S. value of sine curve = 0.707 maximum value Mean value of sine curve = 0.637 maximum value Form factor of sinusoidal = RMS Value /Mean Value = 1.11
Frequency of alternator =pN/60 cycles per second Where p = number of pairs of poles N = rotational speed in r/min Instantaneous value = Maximum value × Sin (2πft) Note: calculator must be in radian mode
Slip of Induction Motor
((Slip speed of field - speed of rotor)/Speed of field) * 100
Current in AC Circuit
Current = impressed volts/impedance
Power Factor
p.f. = true watts/(volts x amperes)
also p.f. = cos Φ, where Φ is the angle of lag or lead
