Understanding the Two Essential Types of Grounding: PE vs. FE
[color=#ff0000] Understanding the Two Essential Types of Grounding: PE vs. FE[/color]
In electrical engineering, [color=#1E00A3] “grounding” [/color] is a fundamental concept but it performs two different principal functions.
It is important not to get confused
  • Protective Earth (PE) and
  • Functional Earth (FE).
[color=#ff0000] Protective Earth (PE) [/color]
PE stands for people (safety)
[color=#21855c]Identification: [/color]Usually has a green & yellow conductor.
[color=#21855c]Primary function: [/color]Discharge dangerous fault currents securely to ground. This action activates protection mechanisms such as circuit breakers & fuses.
[color=#21855c]Purpose: [/color] The top priority is to prioritize safety. The fundamental purpose of PE is to save lives by preventing electric shock & lowering fire danger.
[color=#ff0000] Functional Earth (FE) [/color]
FE stands for function (performance).
[color=#21855c]Identification: [/color] Typically a metallic braid (or) shield.
[color=#21855c]Primary Function: [/color] Provides a reference point to reduce EMI, noise, and increase EMC stability.
[color=#21855c]Purpose: [/color] The main purpose is to ensure performance and reliability. The purpose of FE is to make sure that sensitive electronic equipment operates correctly and dependably by providing a “clean” signal reference.
