Types of Power Transmission Tower Lines
Transmission towers are an important part of the electrical power transmission network.
They support conductors and maintain the required mechanical strength and electrical clearances.
1). Suspension / Tangent Tower
Used mainly on straight sections of a transmission line.
2). Tension / Strain Tower
Designed to withstand conductor tension and used at section points and important crossings.
3). Angle Tower
Used where the transmission line changes its direction.
4). Dead-End / Terminal Tower
Used at the end of a line or near substation entry/exit points and designed for high conductor tension.
5). Transposition Tower
Used to change the physical position of the three-phase conductors to maintain better electrical balance.
6). Special Tower
Used for special requirements such as river, railway, highway or long-span crossings.
Tower classification by circuits:
[center]Single Circuit → Double Circuit → Multi Circuit[/center]
Typical Power Flow:
[center]Generating Station → Step-Up Transformer → Transmission Line → Grid Substation[/center]
The correct tower design depends on voltage level, line angle, span, conductor loading, terrain, wind conditions and crossing requirements.
