Type of Motor Protection
Different Types of Motor Protection are:
  1. Overload Protection
  2. Short-Circuit Protection
  3. Ground Fault (Earth Fault) Protection
  4. Phase Failure (Single Phasing) Protection
  5. Phase Sequence Protection
  6. Under-Voltage Protection
  7. Over-Voltage Protection
  8. Locked Rotor Protection
Protects motor from running at high currents for too long (due to mechanical overload, jam, etc.).
Example: Thermal overload relay.
Protects motor winding from very high fault currents.
Example: Circuit breakers (MCB, MCCB, fuse).
Protects against leakage currents to earth, preventing electric shock and fire.
Example: Earth fault relay.
Protects against loss of one phase in 3-phase motors.
Example: Phase failure relay.
Ensures correct rotation direction and protects against wrong phase sequence.
Example: Phase sequence relay.
Trips the motor if voltage drops below safe limits, preventing overheating or stalling.
Example: Under-voltage relay.
Protects against high voltage which can damage insulation.
Example: Over-voltage relay.
Protects when the rotor cannot turn while current is high (e.g., mechanical blockage).
