Top 10 Essential Electrical & Motor Troubleshooting Q&As for Engineers
Whether you work in industrial maintenance, MEP projects, electrical commissioning, or motor control, understanding these fundamental troubleshooting concepts is essential for safe and reliable field operations.
  1. Phase Sequence: The sequence in which the three phases of an AC power supply reach their maximum values, commonly represented as L1 → L2 → L3. Correct phase sequence is important for proper motor rotation.
  2. Phase Failure: The loss of one phase in a three-phase power system. It can cause excessive current in the remaining phases, overheating, and potential motor damage.
  3. Voltage Drop: The reduction in voltage that occurs as current flows through the impedance of a conductor or electrical circuit. Excessive voltage drop can affect equipment performance.
  4. Continuity Testing: A test used to verify whether an electrical path is complete. The circuit should be de-energized before using a multimeter in continuity or resistance mode.
  1. Motor Winding Fault Diagnosis: Motor windings can be checked by comparing phase-to-phase resistance and measuring insulation resistance with an insulation resistance tester. Significant imbalance or low insulation resistance may indicate a fault.
  2. NO vs. NC Contacts: NO (Normally Open): The contact remains open in its normal state and closes when operated. NC (Normally Closed): The contact remains closed in its normal state and opens when operated.
  3. Causes of Abnormal Motor Vibration: Common causes include shaft misalignment, bearing wear, rotor or mechanical imbalance, loose mounting, and coupling problems.
  4. Role of an Insulation Resistance Test: An insulation resistance test measures the resistance of electrical insulation between conductors and earth or between conductors. It helps assess the insulation condition of motor windings and cables.
  5. Reasons for High Motor Current: High current can result from motor overload, low or unbalanced supply voltage, phase imbalance, mechanical overload, bearing problems, or other abnormal operating conditions.
  6. Pre-Work Electrical Safety Checklist: Before starting electrical maintenance, follow an appropriate isolation procedure: Supply Isolation → Lockout → Tagout → Verify Absence of Voltage → Begin Work Always follow the applicable electrical safety procedures, site requirements, and approved LOTO practices.
