TN-S vs TN-C-S vs TT Earthing Systems
The key difference between TN-S, TN-C-S, and TT earthing systems lies in the arrangement of the neutral (N), protective earth (PE), and earth-fault current return paths.
TN-S System: Neutral and protective earth conductors are separate throughout the installation, with separate connections to the source.
TN-C-S System: Neutral and protective earth functions are combined in a PEN conductor upstream and separated into N and PE at the designated point.
TT System: The installation uses a local earth electrode, independent of the supply system’s earthed neutral. RCD protection is generally essential for automatic disconnection under earth-fault conditions.
These earthing arrangements influence earth-fault loop impedance, fault current, automatic disconnection time, protective device selection, and electrical safety.
The appropriate earthing system must comply with the applicable electrical standards, utility supply arrangements, and installation protection requirements.
