The thermometer can be calibrated using a comparison method using temperature baths. Temperature measuring devices are dipped in the temperature bath along with reference thermometer and they are compared.
The power provided for the heater is a few watts more than required to keep the bath stable, so the bath temperature rises very slowly and steadily.
Calibrating procedure:
Calibration setup:
The calibration bath is first heated to a few degrees below 100 ° C and then the thermometers are in the bath, with the mercury column just visible above the surface of the oil.
The bath heater is adjusted to bring the bath slowly through the 100 ° C mark once the telescope is positioned and the operator is ready to record the results.
Readings start once the reference thermometers show that the temperature is within approximately three divisions of 100 ° C.
A wristwatch with an alarm indicating 10 second intervals is used to alert the operator to take a reading.
The values of the reference thermometer and the thermometers being calibrated are tabulated in the columns.
Once the comparisons at 100 °C and 101 °C are complete, the thermometers are removed from the bath, cleaned to remove the oil.
Advantages of temperature bath:
The measurements are taken at temperatures randomly distributed across multiple divisions to ensure that the markings of bore and scale are well sampled.
The technique has a relatively low cost and is quicker than the fixed-temperature technique described.
The column of mercury rises steadily as the temperature rises, ensuring the proper shape of the mercury meniscus.
By using stirred alcohol baths, initially cooled with dry ice or liquid nitrogen, the technique allows temperatures down to −80 ° C without the need for coolers.
