Testing & Commissioning of a 400/220/132/66/33 KV Substation
Testing and commissioning of a 400/220/132/66/33 kV substation is the final stage before energization, ensuring that all primary equipment, protection systems, control circuits, and auxiliary systems operate safely and according to design specifications.
The process verifies compliance with IEC and utility standards while minimizing the risk of failures during operation.
Ensuring every component -From Distribution transformer, Power transformer, Circuit breaker, CT, PT, CVT, Lightning Arrester, Isolator, earthing, protection relays, SCADA, DAS- is properly tested before energization is essential for safe operation, reliability, and long-term grid performance.
[center]Right Testing ➜ Safety Operation ➜ Reliable Power[/center]
Before energization, all permits are cleared, protection settings are confirmed, CT/PT polarity is verified, and communication with the control center is established. The substation is then energized in a controlled sequence while monitoring voltage, current, alarms, and equipment performance to ensure safe and reliable operation.
