a)Measurement variable b)Desired variable c)Deviation d)Output
Measurement variable: It is the demand variable measured and controlled.
Desired Variable: it is the demand signal (set point) to which the process variable is controlled.
Deviation: it is the error signal caused by the difference between the measurement and the demand signal.
Output: It is the corrective signal from the controller to the final control element.
