Tan Delta (Dissipation Factor) and Power Factor tests are performed to evaluate the dielectric condition of electrical insulation in transformers, power cables, bushings, current transformers (CTs), and voltage transformers (VTs).
The tests measure dielectric losses by assessing the phase relationship between the applied AC voltage and the resulting insulation current. Increased tan delta or power factor values may indicate moisture ingress, insulation ageing, contamination, or dielectric deterioration.
Test results are compared with manufacturer specifications, applicable standards, and previous test records to assess insulation health.
