Symmetrical vs Asymmetrical Fault Current - What is the Difference?
Every power systems engineer should clearly understand the difference between symmetrical and asymmetrical fault current, because both play different roles in equipment selection and system protection.
A symmetrical fault current is the steady-state RMS short-circuit current that remains after the transient DC offset has decayed. It is calculated using:
An asymmetrical fault current represents the actual current that flows immediately after a fault occurs. It consists of the AC fault current combined with a decaying DC offset, making the initial current significantly higher than the symmetrical RMS value.
Parameter Symmetrical Fault Current Asymmetrical Fault Current
Current Type RMS steady-state Initial peak with DC offset
DC Component No Yes
Primary Use Thermal withstand and interrupting rating Making capacity and mechanical withstand
Influenced by X/R Ratio No Yes
Typical Value Lower Higher
