Dear Sirs,
I would like to ask you for you opinion and help.
We use Gasketed plate heat exchanger for cooling the medium with cooling water. We use feedback control with PID regulator, but I am not sure if PID regulation is the bad choice for this system or the P,I,D constants of regulator is poorly set up. In table I summarize the streams properties.
Temperature (°C)
Flow rate (kg/min)
Cooling water IN
8-10
n/a
Cooling water OUT
n/a
Medium IN
20-27 (>25 in rare cases)
90 - 300
Medium OUT
Requested 20
We are sure, that flow of cooling water is sufficient in all cases, even dont have information about the flow rate. Medium flow rate change by steps and is constant for some time (see figure below typical situation).
According my knowledge (I am not specialized in regulation) PID controller is not good option if the medium flow rate changes in so high peaks, as „ideal“ P,I,D constant for one flow rate (say minimal = 90 kg/min) can be very poor for other flow rate (in our case maximum 300 kg/min). In some cases the temperature of medium is stable, but in some cases is sinusoidal (see figure) with difference between minimal temperature and maximal 2-2,5 °C. This difference is for our process too high, we request to have temperature stable in 0,5 °C, maximum 1°C range.
So my question: is PID regulator for this situation good choice and we need to tune up P, I,D constants or we need to modify our regulation systém.
Thanks in advance for your replies, and if needed more information I will answer them.
J.K.
Update: sketch of system added
**as new member I can not attach files, so if you are willing to take a look, please send me a email and I will send you the figures.
