Substation Interview Question and Answer
1). What is Flexible Bus?
Flexible buses are made up of flexible ACSR or all-aluminium alloy stranded conductors that are supported by strain insulators at each end.
2). What are different insulators employed in substations?
A number of insulators used in substations are:
  • Pin insulators
  • Post insulators
  • Strain insulators.
  • Suspension insulators
  • Hallow apparatus insulators
  • Dead-end insulators
  • Solid core insulators
3). Name the Interlockings provided with Isolators.
The interlocking enabled with isolators include:
  • Interlocking between 3 poles allows for simultaneous action.
  • Interlocking with the circuit breakers.
4). What is Creepage Distance?
Creepage distance is the smallest distance between 2 conducting locations on the insulating material’s surface.
5). What is the Basic Impulse Level (BIL)?
Basic Impulse Level (BIL) refers to the peak value of lightning-induced voltage withstand capabilities of the equipment.
6). What are the disadvantages of Corona?
The disadvantages of Corona include:
  • Corona causes power loss.
  • Corona produces unacceptable noise.
  • Corona causes radio interference.
7). In what way is an isolator different from an Air-Break Switch?
Isolators are utilized to connect (or) disconnect a line entirely when there is no load, whereas air-break switches are utilized to create and break a circuit when there is a load. Arc control devices are included into air-break switches.
8). What is a circuit breaker?
A circuit breaker is a mechanical device that closes or opens contact members, thus closing (or) opening an electrical circuit under normal (or) abnormal conditions.
9). Do we use AC (or) DC to charge a Battery?
A battery must be charged using direct current.
10). State any four types of substations according to the service?
The substations are classified as
  • Transformer substations,
  • Switching substations,
  • Converting substations and
  • Frequency changing substations.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
