It is a trim having a single seat and balance holes on its plug. A single seated balanced trim is used in a process line where the DP across the valve is high. These kind of trims are useful in reducing the vibration on the valve body and also assists in closing the valve.
Direction of flow is usually down for a balanced valve due to the Leak paths
