Load Memory:
The load memory is located on the SIMATIC Micro Memory Card.
The size of the load memory corresponds exactly to the size of the SIMATIC Micro Memory Card.
It is used to store code blocks, data blocks and system data (configuration, connections, module parameters, etc.).
System memory:
The RAM system memory is integrated into the CPU and cannot be expanded.
It consists of: the address areas for address area memory bits, timers and counters.
The processed image of the I/Os
Local data
Work memory:
The work memory is integrated into the CPU and cannot be extended.
It is used to run the code and process user program data.
Programs only run in the work memory and system memory.
