Reset (Rung 1)
- Contact: Reset button (RB)
- Coil: Shift Register Reset (SRR)
Load (Rung 2)
Contact: Load button (LB)
Coil: Shift Register Load (SRL)
Shift (Rung 3)
Contact: Shift button (SB)
Coil: Shift Register Shift (SRS)
Data (Rung 4)
Contact: Data input (DI)
Coil: Shift Register Data (SRD)
How it works?
Reset
When you push the reset button, the shift register is cleared.
Load
When press the load button loads data into shift register.
Shift
When the shift button is pressed, data in the shift register moves one bit to the right (or left).
Data
The data output coil receives the shift register’s data output.
Solved Example
Let’s say we wish to move a 4-bit binary number (1010) to the right by one bit. The following is how the ladder diagram should operate:
Reset: Clear the shift register (0000)
Load: Load the data input (1010) into the shift register
Shift: Shift the data one bit to the right (0101)
Data: The output data is now (0101)
