SF₆ Circuit Breaker Timing Test
The SF₆ circuit breaker - timing test - verifies the operational time of its contacts during opening and shutting operations.
It verifies that the breaker operates within the manufacturer’s specifications and discovers mechanical or control faults.
The timing test evaluates an SF₆ circuit breakers open/close/trip operation time to verify consistent performance.
Breaker analyzers are used to measure important characteristics such as O (Open), C (Close), O-C, C-O duration, and contact travel.
The ideal timing guarantees that the fault is safely cleared.
Key Parameters Measured
- Opening Time
- Closing Time
- Pole Disparity (the time variation in phases)
Safety Protocols
- Isolate the breaker and release accumulated energy.
- Utilize PPE (arc suit, gloves).
- Ensure grounding.
Test Equipment
- Timing test kit (Ex: Omicron, Megger),
- Control cables, and
- DC supply.
Procedure
- Isolate the breaker & connect test equipment.
- Use the test kit to trigger open/close commands.
- Measure & record contact operation times.
- Assess condition by comparing it to standard values.
Advantages
- Prevents breakdowns,
- Improves system reliability, and
- Facilitates preventive maintenance.
This test is essential for assuring proper breaker operation & system protection.
