Hey, the firm/corp I work for is fixing some robots that are going to lift and place packages in a storage facility.But we got met some problems with our BLDC Nanotec Motors. Is there any other firms/corps that make motors which have the same specs as the Nanotec motors or very similar to them.
Specs: 2stk BLDC Motor without Encoder
Nema (newton) : 34
Rated Power : 660W
Rated Current : 17.95 A
Rated Speed : 3000 RPM
Rated Voltage : 48V (Rated voltage must be 48V)
3stk BLDC Motor with Encoder
Nema (newton) : 32
Encoder : yes
Encoder type : Incremental
Rated Power : 942 W
Rated Torque : 300 ncm
Rated Current : 25 A
Rated Voltage : 48 V
5stk Motor Controller for Ethercat
Interface : Ethercat
Rated Current : 18 A
Corresponding Motors : Brushless DC
Motors, Stepper Motor.
Type of Digital Input : 5/24 V switchable / 5 - 24 V
Type of Analog Input : -10 - +10 / 0-20 mA switchable
Type of Digital Output : Open-drain (max 24V / 500mA)
Encoder Signal Type : Incremental
Operating Voltage : 12 VDC - 48 VDC
Peak Current : 40 A
