I have been having some issues with SIMOTION D the green ready light is blinking off and on, what is the problem
It looks like it’s looking for a signal or it could be a secondary contact on the main isolator or contactor. The power module has no power you have no indication at all, make sure that the 24v is on the drive first but please take care as the 600v rails are behind the cover too it may just be a bad connection if your removing the drive if you have double-checked the control voltage please leave the drive powered down for at least 20 mins to allow for discharge.
Also, check your dc voltage out of your smart module it could be internal and it is looking for the drives you should be around 600v dc
I think if the problem is not solved then you need to download the progarm back in
