Problems in vibration probe
Series Industrial Transmitter, with Dynamic Signal Sensor ,. my problem is the vibration probe it shows 0mm/s on DCS but the Cooling fan still working and I have checked terminal Already there is supply 19 Vdc.
Check the connection, the minimum voltage required is 22-30 vDC. then you check field side I mean sensor side light hammering of the sensor and set up it
