Selection Tips of pressure gauge
Pressure gauge must be selected in terms of scale range and design.
The scale range is optimally selected when the operating pressure lies in the middle third of the scale range.
The pressure gauge must be mounted free from vibration and should be aligned so that it is easy to read.
The process connection must be sealed properly.
The installation of a shut-off device between pressure tapping and pressure gauge is recommended for maintenance and replacement.
For non-hazardous, liquid media < 25 bar without case filling, no safety level is required.
SPECS of Bourdon Tube type
- Type of measuring element (C-type, helical type, spiral type)
- Electrical output (without, digital output, analog output)
- Ingress protection IP (for guage with electrical output only)
- Scale (Single scale, Dual scale)
- Measuring element (Copper alloy, Stainless steel
- Movement material Brass) (cupper, stainless steel,
- Measuring media (gaseous, liquid)
- Nominal Dial size NS (outer diameter Ø) (1, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 6, 10 inch)
- Mounting connection location (Centre back, lower (radial), Lower back)
- Scale ranges (from x to y bar)
- Window type Polycarbonate) (Plastic, Laminated safety glass,
- Case material (Plastic, Stainless steel)
- Case design level S1/S2/S3) (Without safety level, with Safety
- Case filling (Without, Glycerine, Glycerine-water mixture, Silicone oil
- Accuracy class (Class 0.1 (± 0.1% of span), 0.25, 0.6, 1, 1.6, 2.5, 4)
- Increased overload safety (Without, 1.6 times, 2 times
- Process connection size (1/8 NPT, 1/4 NPT, 3/8 NPT, 1/2 NPT)
- Process connection material (Copper alloy, Stainless steel)
- Dial and pointer specs if required
- Operating conditions specs if required
