[color=#CF2E2E] Power System Abbreviations [/color]
The following is an ideal collection of 68 abbreviations that are essential for the power sector.
Even while it covers a wide range of common terms, such as [color=#1E00A3] “Automatic Voltage Regulator (AVR)”[/color] and “Generator Circuit Breaker” (GCB), we all have certain acronyms that are special to our field, whether it be protection, renewables (or) design and they are a part of everyday conversation.
[color=#CF2E2E] Electrical Abbreviations and Their Full Forms [/color]
1. EHV – Extra High Voltage
2. HV – High Voltage
3. MV – Medium Voltage
4. GW – Gigawatts
5. NTPC – National Thermal Power Corporation Limited
6. NHPC – National Hydroelectric Power Corporation Limited
7. NLC – Neyveli Lignite Corporation of India
8. ckms – Circuit Kilometers
9. LA – Lightning Arrestors
10. WT – Wave Trap
11. CVT – Capacitive Voltage Transformer
12. ISO – Isolate
13. CB – Circuit Breaker
14. CT – Current Transformer
15. DCDDB – Direct Current Distribution Board
16. ACDB – Alternating Current Distribution Board
17. DC – Direct Current
18. AC – Alternating Current
19. CHP – Combined Heat and Power
20. CSP – Concentrated Solar Power
21. PV – Photovoltaic
22. IGBT – Insulated Gate Bipolar Transistors
23. GT – Generator Transformer
24. AAC – All Aluminium Conductor
25. AAAC – All Aluminium Alloy Conductor
26. ACSR – Aluminium Conductor Steel Reinforced
27. ACAR – Aluminium Conductor Alloy Reinforced
28. SCCW – Stator Coil Cooling Water
29. DM – Demineralization
30. LMTG – L&T MHI Power Turbine Generator
31. VPI – Vacuum Pressure Impregnation
32. TG – Turbo Generator
33. AVR – Automatic Voltage Regulator
34. PLC – Programmable Logic Controller
35. IS – Indian Standards
36. IEC – International Electrotechnical Commission
37. IEEE – Institute of Electrical and Electronics Engineers
38. SLD – Single Line Diagram
39. ST – Station Transformer
40. GCB – Generator Circuit Breaker
41. IPBD – Isolated Phase Bus Duct
42. GSUT – Generator Step-Up Transformer
43. UPS – Uninterrupted Power Supply System
44. DG – Diesel Generator
45. CCPP – Combined Cycle Power Plant
46. DCS – Distributed Control System
47. BOP – Balance of Plant
48. UMPP – Ultra Mega Power Plant
49. SP – Set Point
50. DMZ – Demilitarized Zone
51. HMI – Human Machine Interface
52. LDC – Load Dispatch Center
53. OEM – Original Equipment Manufacturer
54. SCADA – Supervisory Control and Data Acquisition
55. ISO – International Standards Organization
56. OSI – Open System Interconnect
57. DSSS – Direct Sequence Spread Spectrum
58. ISM – Industrial Scientific and Medical
59. FF – Foundation Fieldbus
60. LSA – Link Active Scheduler
61. PROFIBUS – Process Field Bus
62. PA – Process Automation
63. DP – Decentralized Periphery
64. STP – Single Twisted Pair
65. IMC – Intelligent Motor Control
66. OLM – Optical Link Module
67. ODC – Over Dimension Consignment
68. OWC – Overweight Consignment
