Pneumatic Actuators and Key Components
[color=#ff0000]Pneumatic Actuators and Key Components[/color]
Pneumatic actuators employ compressed air to move devices (often linear or rotational) in automated processes.
The pneumatic actuation system consists of many essential components to assure control, safety, & efficiency.
1). Pneumatic Actuator
2). Solenoid Valve
3). Filter/Regulator (FRL Unit)
4). Limit Switch Box
5). Booster (Air Volume Booster)
6). Flow Regulator
[color=#21855c]1). Pneumatic Actuator[/color]
Converts compressed air to mechanical action.
May be linear (cylinders) (or) rotary (to turn valves, arms, etc.).
[color=#21855c]2). Solenoid Valve[/color]
An electromagnetically controlled valve.
Controls the air flow to extend (or) retract the actuator.
Depending on the actuator design, 3/2 (or) 5/2 valves are commonly used.
[color=#21855c]3). Filter/Regulator (FRL Unit)[/color]
A filter eliminates pollutants from compressed air.
The regulator maintains air pressure at a safe, ideal level.
Frequently paired with a lubricator (FRL unit) to extend component life.
[color=#21855c]4). Limit Switch Box[/color]
Mounted on rotary or valve actuators.
Gives input on the actuator’s position (open/closed).
Sends signals to the control systems and PLCs.
[color=#21855c]5). Booster (Air Volume Booster)[/color]
Increases the flow (or) pressure of the compressed air to actuator.
Aids in faster actuation in situations where long air lines induce pressure loss.
[color=#21855c]6). Flow Regulator[/color]
Regulates the speed of actuator movement by limiting air flow.
Installed on the exhaust ports (or) lines leading into the actuator.
Helps to prevent slamming or jerky action.
[color=#ff0000]Application[/color]
  1. A rotary pneumatic actuator opens and shuts the valve.
  2. A solenoid valve causes movement.
  3. A filter-regulator maintains clean and consistent pressure.
  4. A flow regulator regulates motion speed.
  5. A limit switch box provides open/closed feedback.
  6. A booster ensures quick and forceful action as needed.
