A control valve is said to be oversized when a minimum signal to the valve (minimum opening of the valve) brings process to the set point rapidly. This situation leads to an imbalance and high gain in the control loop. The problem can be solved by changing the valve trim to a reduced trim size or by replacing the control valve for the correct size.
