##Principle:
Optical flowmeter uses light reflection to measure the velocity of the flow stream. It measures the time of flight of light to measure the flow of a stream.
##Construction and Working:
A dual beam laser is used as the source
Opposite sides of the pipeline is attached with optical window to let the light into the pipeline.
The light detecting sensors are placed at an inclination to the straight line path of the light.
The light detected is then converted into an electrical signal and then signal processed.
The light is let pass through the optical window and the light propagate through the fluid and comes out through the optical window at the other end.
If there is no fluid flow in the pipeline, the light goes straight and cannot be detected by the sensors.
If fluid flows through the pipeline. The incident light hits the particles in the fluids, the light gets scattered and deviates from the main path.
The deviated light is getting detected by the detector. Consider this happens at the first sensor. Then the particle moves further to the second beam of light.
The same happens for the second beam. The light beam gets deviated and detected at the second sensor. The time delay between the two successive pulse is measured.
This time delay is proportional to the flowrate of the stream, desicribed by the equation:
V=d/t
Where, v = Velocity of particle d = Distance separating laser beams t = Time difference between sensor pulses
