The installation was done as a SCADA install, rather than a Process install. When choosing the node type, the C200/300, ACE, SIM check box was unchecked.
The installation type can be confirmed via the 2 following registry entries. SCADA installation, Flex. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“SCADA Client” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”=“No”
Process installation, Flex. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“Process Client” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”="Yes”
SCADA installation, Server. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“SCADA Server” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”=“No”
Process installation, Server. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“Process Server” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”="Yes”
SCADA installation, Console Station. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“SCADA Station” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”=“No”
Process installation, Console Station. [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey"=“Process Station” [HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo\Engineering Tools\ “IsCDA”="Yes”
Note: The “[HKEY_LOCAL_MACHINE\SOFTWARE\Honeywell\TPS50\InstallInfo"InstallProductKey” may vary between releases.
