Megger / Insulation Resistance (IR) Test QA/QC Checklist
A Megger or Insulation Resistance (IR) Test is a critical QA/QC inspection used to verify the insulation integrity of cables, motors, transformers, switchgear, and electrical panels before commissioning. It helps identify moisture, contamination, insulation deterioration, and potential faults that could lead to equipment failure.
Before the Test
Ensure the equipment is completely isolated and de-energized using proper LOTO procedures.
Verify there is no stored electrical charge and discharge capacitive circuits.
Disconnect sensitive electronic devices if required.
Select the correct Megger test voltage (250V, 500V, 1kV, 2.5kV, or 5kV) according to equipment ratings.
Record ambient temperature and humidity.
During the Test
Inspect the Megger leads for damage and proper connections.
Connect the test leads to the appropriate terminals.
Apply the test voltage for the specified duration, typically 1 minute.
Record insulation resistance values in megaohms (MΩ) or gigaohms (GΩ).
Compare phase-to-phase and phase-to-earth readings for consistency.
After the Test
Safely discharge the equipment before disconnecting the test leads.
Restore all removed connections and protective covers.
Compare measured values with manufacturer recommendations or applicable IEC/IEEE standards.
Document test voltage, duration, readings, temperature, humidity, equipment identification, and tester details.
Mark the equipment as Pass or Fail, and investigate any abnormal or low insulation resistance values before energization.
A well-documented IR Test checklist improves commissioning quality, enhances electrical safety and helps ensure reliable long-term equipment performance.
Inspection Item QA/QC Check Status
Work Permit Valid work permit available ☐ Pass / ☐ Fail
Equipment Isolation Equipment fully isolated and LOTO applied ☐ Pass / ☐ Fail
Voltage Verification Confirm equipment is de-energized ☐ Pass / ☐ Fail
Stored Energy Capacitive circuits discharged ☐ Pass / ☐ Fail
Visual Inspection No visible damage, moisture, or contamination ☐ Pass / ☐ Fail
Sensitive Devices Electronic devices disconnected if required ☐ Pass / ☐ Fail
Megger Condition Test instrument calibrated and in good condition ☐ Pass / ☐ Fail
Test Leads Leads inspected for damage ☐ Pass / ☐ Fail
Test Voltage Correct test voltage selected (250V/500V/1kV/2.5kV/5kV) ☐ Pass / ☐ Fail
Temperature Ambient temperature recorded ☐ Pass / ☐ Fail
Humidity Relative humidity recorded ☐ Pass / ☐ Fail
Phase-to-Earth Test Reading recorded ☐ Pass / ☐ Fail
Phase-to-Phase Test Reading recorded ☐ Pass / ☐ Fail
Test Duration Voltage applied for specified time (typically 1 minute) ☐ Pass / ☐ Fail
Reading Stability IR values stable during the test ☐ Pass / ☐ Fail
Equipment Discharge Equipment discharged after testing ☐ Pass / ☐ Fail
Connections Restored All disconnected cables restored ☐ Pass / ☐ Fail
Protective Covers Covers and barriers reinstalled ☐ Pass / ☐ Fail
Standard Compliance Results compared with IEC/IEEE or manufacturer limits ☐ Pass / ☐ Fail
Final Documentation Test report completed and signed ☐ Pass / ☐ Fail
Typical Insulation Resistance Test Voltages
Equipment Rating Recommended Test Voltage
Control Circuits 250 V DC
LV Equipment (Up to 500 V) 500 V DC
500–1000 V Equipment 1000 V DC
MV Equipment 2.5 kV DC
HV Equipment 5 kV DC or as specified by the manufacturer
Test Record Summary
Parameter Value
Equipment Name __________
Equipment Tag __________
Location __________
Test Date __________
Test Voltage __________ V
Test Duration 1 Minute
Temperature __________ °C
Humidity __________ %
Phase-to-Earth Reading __________ MΩ/GΩ
Phase-to-Phase Reading __________ MΩ/GΩ
Result PASS / FAIL
Tested By __________
Witnessed By __________
This tabulated QA/QC checklist provides a practical inspection format for pre-commissioning and commissioning IR tests, ensuring consistent documentation and compliance with IEC and IEEE testing practices.
