Valve installations are subject to numerous standards and specifications issued by many supporting organizations. Valve standards are vibrant documents representing engineering practices, variations in market requirements and technological and production process modifications.
These are the list of valve standards:
American Petroleum Institute (API) standards
ASME
Manufacturers Standardization Society – Standard Practices (MSS – SP)
INDIAN STANDARDS : Bureau of Indian Standards (BIS)
American Petroleum Institute (API) standards:
The most common valve design standard for the past 50 years has been the American Petroleum Institute (API) valve standard for refinery use, known today as API 600. The American Petroleum Institute (API) Standards for Some Commonly used Valves are as follows
| Standard |
Specifications |
| API 6D | Pipe Line Valves, End Closures, Connectors and Swivels |
| API 6F | Recommended Practice for Fire Test valves |
| API 593 | Ductile Iron Plug Valves – Flanged Ends |
| API 598 | Valves Inspection and Test |
| API 600 | Steel Gate Valves |
| API 602 | Compact Design Carbon Steel Gate Valves |
| API 604 | Ductile Iron Gate Valves – Flanged Ends |
| API 607 | Fire Test for Soft Seated Ball Valves |
ASME:
ASME (American Society for Mechanical Engineers) is a nonprofitable organization. ASME provides 600 codes and standards covering many technical areas, such as fasteners, plumbing fixtures, elevators, pipelines, and power plant systems and components.
| Standard |
Specifications |
| ASME B16.34 |
Valves – Flanged, Threaded and Welding End |
| ASME B16.10 | B16.10 lists the face to face dimensions of all flanged and buttweld end valves. Screwed and socket weld end valve face-to-face dimensions are not included in this specification |
| ASME PTC 25 | The main reference document for the testing of pressure relief valves |
Manufacturers Standardization Society – Standard Practices (MSS – SP):
The Valve and Fittings Industry MSS is a non-profit technical association organized for industrial growth and enhancement, domestic and global codes and norms for: Valves, Valve Actuators, Valve Modification, Pipe Fittings, Pipe Hangers, Pipe Supports, Flanges, and Associated Seals.
The most Common MSS-SP standards referred for Valves are as follows:
| Standards | Specifications |
| MSS – SP – 42: | Class 150 corrosion resistant gate, globe and check valves |
| MSS – SP – 61: | Pressure testing of valves |
| MSS – SP – 67: | Butterfly Valves |
| MSS – SP – 68: | High Pressure off seat butterfly valves |
| MSS – SP – 70: | Cast iron gate valves |
| MSS – SP – 71: | Cast iron check valves |
| MSS – SP – 72: | Ball Valves |
| MSS – SP – 78: | Cast iron plug valves |
| MSS – SP – 80: | Bronze gate, globe and check valves |
| MSS – SP – 85 | Cast iron globe valves |
Indian Standards cover Dimensional and Material Specifications under the same Standard Number: Some of Piping Engineers ’ frequently referred Indian standards are as follows:
| IS 778: | Specification for Copper Alloy Gate, Globe and Check Valves |
| IS 780: | Specification for Sluice Valves – 50 NB to 300 NB |
| IS 2906: | Specification for Sluice Valves – 350 NB to 1200 NB |
| IS 4038: | Specifications for Foot Valves |
| IS 5312: | Specification for Check Valves |
| IS 6157: | Inspection and Testing of Valve |
| IS 10605: | Steel Globe Valves for Petroleum Industries |
| IS 10611: | Steel Gate Valves for Petroleum Industries |
| IS 10805: | Foot Valves |
| IS 11790 | Code of practice for preparation of Butt welding ends for valves, flanges and fittings |
| IS 11792 | Steel Ball Valves for Petroleum Industry |
| IS 13095 | Butterfly Valves |
