There are several companies that manufacture HART communicators, including:
- Emerson Process Management
- Yokogawa Electric Corporation
- Beamex.
- Fluke
- ABB Group
These companies offer a range of HART communicators that are designed for use in different applications and environments. Some of the features that may be offered by these devices include the ability to communicate with multiple field devices simultaneously, support for multiple languages, and advanced diagnostic and troubleshooting capabilities.
Here is a list of some HART communicators from various manufacturers:
- Emerson HART 375 and HART 475 Field Communicator
- AMS Trex Device Communicator
- Beamex MC6
- Fluke 754
- Yokogawa HART Communicator YHC5150X
1.Emerson HART 375 and HART 475 Field Communicator
The 475 Field Communicator won’t be for sale any longer. Still these models widely used in industry.
Some of the features of HART 375 and HART 475 communicator is given below.
- Compatibility with HART field devices: Both of these communicators are designed to be used with a wide range of HART-compatible field devices, including transmitters, valves, and controllers.
- Easy-to-use interface: The HART 375 and HART 475 communicators feature a user-friendly interface that makes it easy to navigate and configure field devices.
- Advanced diagnostic capabilities: Both of these communicators offer advanced diagnostic features that allow users to quickly identify and troubleshoot problems with field devices.
- Customizable display: The HART 375 and HART 475 communicators allow users to customize the display to show the information that is most relevant to their needs.
- Multiple language support: Both of these communicators support multiple languages, making them suitable for use in a variety of international settings.
2.AMS Trex Device Communicator
AMS Trex Device Communicator is a replacement for Emerrson HART 475 communicator.
Some of the features of AMS Trex Device Communicator is given below.
- Compatibility with HART and FOUNDATION fieldbus devices: The AMS Trex Device Communicator is designed to be used with a wide range of field devices, including HART and FOUNDATION fieldbus transmitters, valves, and controllers.
- Easy-to-use interface: The AMS Trex Device Communicator has an easy-to-use interface that makes it simple to find your way around and configure field devices.
- Advanced diagnostic capabilities: Offers a wide variety of configuration and troubleshooting options for HART and FOUNDATION Fieldbus devices. Supports troubleshooting and validation of FOUNDATION Fieldbus segments.
- Loop Diagnostics: Perform loop troubleshooting and checkouts while the loop is powered in the field. Investigate and resolve wiring problems as well.
- WirelessHART Provisioning: Supports wirelessHART configuration.
- Radar Master: Supports configuration of Rosemount radar transmitter.
- ValveLink Mobile: Without disrupting the process, analyze valve assembly condition and performance.
- Calculator and Unit Convertor: In built calculator and Unit convertor is available.
- PDF Viewer: In built PDF reader is available. User manuals can be directly accessed.
3.Beamex MC6
Features of Beamex MC6 is given below.
- Compatibility: Supports HART,Foundation FieldBus H1, Profibus PA
- High Accuracy: The MC6 is an advanced, highly accurate calibrator and a portable HART communicator.
- Loop Supply:The MC6 also features a built-in HART compliant loop supply as well as the needed impedance, eliminating the need for extra supplies.
- Communicator/Calibrator: MC6 can be used as communicator or calibrator.
- Easy to use and Reliable
- Easy documentation: Calibration certificates can be automatically generted.
- User interface Modules: MC6 Supports 5 user interface modules Communicator, Meter, Calibrator, Documenting Calibrator, Data Logger.
4.Fluke 754 Documenting Process Calibrator-HART
Features of Fluke 754 is given below.
- HART communication: The Fluke 754 is able to communicate with HART-enabled field devices using its built-in HART modem. This allows users to perform a range of tasks, including device configuration, diagnostic testing, and process variable measurement.
- Dual display: The Fluke 754 features a dual display that allows users to view process variables and measurement data simultaneously.
- Documenting capabilities: The Fluke 754 has the ability to create detailed documentation of calibration and test activities, including test results, procedures, and measurement data.
- Measurement and Source capabilities. AC/DC voltage, mA loop w/ 24V loop power, Pressure, Thermocouples & RTDs, Frequency, Resistance
- Calibrator: Calibrator for pressure, temperature, and mA loops.
- Documentation: Calibration procedures can be created. Calibration results can be documented automatically.
- Calibration Management Software : Can be connected with a calibration management software.
5.Yokogawa HART Communicator YHC5150X
Features of HART Communicator YHC5150X is given below.
- Reads DDs from manufacturers in their native format, eliminating the need for translations.
- Any registered or unregistered HART Device can communicate with a HART-compliant modem.
- Handheld design.
- In built QWERY keyboard.
- High battery capacity
- Multi language support
