Can we use flow switch in place of a level switch
Typically your level switch is monitoring static level. A flow switch won’t pick up a static level. Maybe if the flow is differential pressure and you compare atmospheric pressure to the level created by the level I guess. Using it as a pressure switch at that point you can change a level and pressure switch but flow and level no.
