Can we connect 8-13A double socket on a 15A breaker
You can connect 8 13A duplex sockets in a ring circuit, and breaker 15A, if the connected total load never exceeds 15A. Yes, you can connect but the Load shouldn’t exist more than 15 Amps At the same time. Because 8-13 Amp is your Full load current. Use 30Amps breaker… Redial connection… 2.5mm2 3 core cable
