Industrial Control Panel
An industrial control panel integrates all the essential components required to monitor, control, and protect industrial processes.
Power Supply Units (AC/DC) – Provide stable power to PLCs, sensors, relays, and communication devices.
Protection Devices – Circuit breakers and overload relays protect equipment from short circuits and overcurrent conditions.
Terminal Blocks (DIN Rail Terminals) – Ensure organized and reliable field wiring connections.
PLC (Programmable Logic Controller) – The brain of the system, executing control logic and process automation.
I/O Modules – Interface between the PLC and field devices, handling digital and analog signals.
Relay Modules – Electrically isolate and switch loads safely.
Sensors & Actuators – Collect process data and execute control actions.
Industrial Ethernet/GSM Communication – Enable remote monitoring, diagnostics, and data exchange.
Industrial Network Switch – Connects PLCs, HMIs, SCADA systems, and other smart devices.
