Symptoms:
- The flow meter reading is erratic or significantly deviates from the expected flow rate.
- The flow meter shows zero flow when there is actual flow in the pipe.
- The displayed flow rate fluctuates rapidly.
Symptoms:
Ok, as i see the picture, i suppose that you’re talking about a Promag. So, many causes here:
Something else, I hope that your pipes are conductive (metal…) and linked to the ground. If not (plastic, fiber or PVC pipes.) you’ll need a circular ground plate to install between your flowmeter and the pipe. To create the electrical loop. Without that, no measure or random values.
Insufficient upstream straight pipe section: Typically requires ≥10D, where D is the pipe diameter. Solution: Ensure the installation location has sufficient straight pipe sections. Incorrect electromagnetic flowmeter installation orientation: Should be installed horizontally or vertically. For vertical installation, fluid should flow from bottom to top. Solution: Reinstall to ensure correct orientation. Electromagnetic flowmeter requires full pipe measurement: Partial pipe filling causes measurement errors. Solution: Ensure full pipe flow; install air vent valves if necessary. Electromagnetic flowmeter conductivity requirements not met: Only suitable for liquids with conductivity ≥5 μS/cm. Solution: Select a flowmeter suitable for low-conductivity liquids or change the medium. Medium contains gas or solid particles: Affects measurement signals. Solution: Install air vents or filters to ensure medium purity. Poor electromagnetic flowmeter grounding: Causes signal interference. Solution: Inspect grounding system to ensure proper grounding. Power voltage fluctuations: Affect normal flowmeter operation. Solution: Use a regulated power supply to ensure stable voltage. Loose or damaged cable connections: Cause unstable signal transmission. Solution: Inspect cable connections and replace cables if necessary. By inspecting installation, medium, electrical connections, parameter settings, and equipment status, along with regular calibration, measurement inaccuracies can be effectively resolved to ensure measurement precision and long-term stable operation.
