Is it possible to use the pitot tube in vertical lines
. Yes you can use it, We can apply the pitot tube in horizontal, vertical, or inclined
The recommendation for any differential pressure primary flow element is that the vertical flow be up, not down, to ensure a full pipe. ‘Full pipe’ is an assumed requirement for all DP primary flow elements.
