Uploading from PLC Program and Hardware configuration from PLC to PC procedure - Siemens SIMATIC MANAGAER
Step By Step Procedure
1.Create a new project.
2.Then Go to following menu
PLC>Upload station to PG…
3.A new window will pop up “Select Node Address”
Click on “View”. Then select the “IP address” of the Siemens PLC you would like to upload it to computer.
Then click on “OK”
Program is being uploaded to PG.
4.Expand the tree and select the hardware to see hardware configuration .Select “OB1” to see the ladder program.
