This guide explains, in practical engineering terms, how to select and calculate the size of a busbar for low-voltage panels according to both IEC and NEC standards.
It walks you through every stage - from calculating current, applying derating factors, choosing the correct cross-section, and verifying temperature rise, to short-circuit and mechanical checks.
You’ll also see the exact IEC and NEC references you should cite, plus real working examples for a 500 kW / 400 V / 3-phase load.
At the end, you can check or verify your result using the KW Calc Busbar Size Calculator - it applies the same logic automatically.
